the beyonder
- Apr 7, 2011
- 2
I just bought a 22' WA Angler with a 1995 Johnson 225 Ocean Runner. I am having an issue with the motor stalling at low idle in neutral and in gear at low rpm in both forward and reverse. The motor actually runs awesome when throttled up at the higher Rpms. When I start up at home with the rabbit ears on the lower end the motor runs and runs in idle but for some reason stalls out in the river at low Rpm( Indian River, Melbourne, fl ). Motor does not smoke alot doesnt sneeze or cough. Again the motor stands the boat right up. someone told me to either adjust the idle or perhaps add Seafoam to clean the carbs up abit. the compression is 110 psi in all 6 cylinders and the plugs look good. I talked to the mechanic that serviced the boat before I bought and he told me he cleaned the carbs back in Dec of last year.
Any suggestions? Thanks
