hogginhank
- Oct 20, 2009
- 53
Well I posted up a week or so ago and I have finally got a few hours to start the process of replacing my water pump and thermostat.. Well I am at a stopping point just a little ways into it. As someone said , I have the service manual by CLYMER and I can say now that I want to burn it!! I have replaced a lot of small outboard impellers up to a 35 hp evinrude..I found linkage on the rest but this one is kicking my butt bigtime.. The manual doesn't have anything on step by step procedures..
With that said, incase you ask, I have a 1995 E50 DTLEOS 50HP - 3cylinder evinrude. I took off the prop, drained the lower unit and the 4 main bolts are off. I took out the pinion gear retaining screw(It really doesn't say ANYTHING about needing to remove this or not??) and it seems like it is bolted tight still. Some gentle taps with a board and hammer show no signs of movement.. Does anyone have any tips or info that will save me from having a stroke over this dadgum motor..Thanks in advance.. Hank
