I recently replaced my lower unit, water pump and housing. Water tested engine in a
tub it ran good seems to only spit out water, not a constant stream. Took boat to the lake ran the motor for a few minutes on the lake and it ran strong very good. I thought that after it warmed up and the thermostat opened up the water flow would be better than just spitting out the water outlets. My question is should there be more flow out the water outlets? The motor is not overheating it runs very good, maybe I'm being paranoid
