j_k_bisson
- Oct 6, 2010
- 1,082
It coming close to the time when I will be starting up the new resto built 1987 225hp Evinrude. VRO bypassed and run premixed. Trying to figure out which oil to use on breaking it in. The fuel unfortunately will be 10% ethenol (no non-ethenol gas around) with BRP 2+4 Fuel Conditioner , along with BRP Carbon Guard and BRP fuel system cleaner.
Basically I want to treat the gas for the ethenol issue and the motor for carbon build up and the fuel system (carbs) for a cleaning for anythign I missed.
So my question is what oil to use. I am using the BRP branded oils but should I use xd-30 (non synthetic) or xd-50 (blended synthetic) Will the xd-50 ruin the breakin?
Other option is the first 6 gallons I could use a portable tank with the xd-30 premixed and then switch over to the main tank (82 gallons premixed) with xd-50.
Eventually I will probably run the xd-50 or xd-100 to keep down on the fumes. That will be a mater of cost later. Right now cost is not the factor.
Also if I can get 91 octane gas that is non ethenol blended should I use it for break in period? Or will it run too hot.
Any and all thoughts welcomed.
PS. for those who are following the resto thread, Bay Mfg is shipping out the extention kit by the end of the week. So the end is near!
