Well I've been stumped and needed some help on this. I have a 1990 40hp evinrude vro model# e40 elesr. Previously the vro pump went out and I've rebuilt the motor and completely removed the vro pump. Now I've installed a new fuel pump from Sierra that bolts to the engine and I know it's the right pump but don't have the part number on hand. To get to the problem, I installed the new pump ran my hose from the tank and then my out fuel line goes into the top of the plastic fitting that has three more lines off of that. 2 of which go to the carbs and one that goes to the electric choke all hooked up. 2 more hoses come from the electric choke and go into the top of both carbs now the engine will start but only if we choke it by putting our hand over the carbs will it run but rough. Now moving over to the electric choke part. With the red lever down it seems to not be getting enough gas but switching the lever up it drowns the carbs with gas either way it runs like crap and won't run on it's own. I'm thinking maybe it's the carbs but we pulled them off and they looked very clean. I'm thinking I hooked things up correctly but any help would be greatly appreciated!
