Have a trailer that came with the used boat. Trailer and wire appear to be in great shape. When plugged in to the van I get no lights on the trailer.
Tested ground at the van harness-good. Tested voltage at the van pins for each light-good.
Tested trailer ground at bulb -good. Tested trailer wiring with power supply-lights light.
Tested ground from van to trailer when mated - good.
Jumpered across for the tail lights - worked.
Plug is hard to mate but appears to be seated.
Any ideas?
Thanks
Any ideas?
Thanks
