Hi there. My wife and I are working out the details but we are expecting to purchase a mid 90's 22' Pontoon with 25" toons. It currently has a 40hp Force motor (2 stroke I assume). I have a late 90's Bigfoot 50hp 4 stroke motor on the back of the tri hull I have now. I plan on selling the trihull as soon as we get the pontoon and my question is this. Is it worth all the work to swap the motors? I know it is 20% more horsepower, but I would assume it is considerably heavier. Both the controls should pretty well match right up, but if not I will swap control boxes and/or wiring harnesses.
Basically my wife wants to know if the boat is running 17ish mph now is it worth spending a weekend doing all this. I know the newer/better motor has a higher resale value too so this will go into consideration. Both motors run like champs too. I was just curious if the weight added to hp gained would basically make it a wash...even if so we might swap them as my motor is much much much quieter and there is no oil to mix, just change it once a year.
