Hi folks,
E235STLCOR
Trying to chase down this last gremlin in this motor. I believe there are a couple of issues here including, wrong parts for the year, superceeding part numbers, and bad parts altogether.
The Motor runs great, no issues there. However, it doesn't charge, nor does the tach work now. The tach worked for about 2 years after I got the motor, but a couple of weeks ago it stopped. Now it goes up to about 1100 RPMS at idle(on the hose) and when you give it gas it goes back down to 0.
Now here is where I'm confused. I understand that it probably need a new rectifier/regulator but I'm confused on what part number to look for.
I've looked it up in the parts diagram and it calls for a omc # 395391
The part number that is on there now is a omc #583268
I also have a omc #583076 That I have tried and it doesn't work either.
So I looked at the stator to see if it might be bad and it has an omc# 581987 on it. I'm not even sure this is the right stator becuase the book calls for an omc# 582867 The tach works if I move the tach signal over to the yellow stator wire.
So what is the issue? Is it just a bad regulator/rectifier or do I have wrong parts or what? I'm nearly out of money with this thing and I just want it to charge so I don't have to worry about it running down anymore when I'm out. Thanks for the help and sorry for the long post.
E235STLCOR
