SBC Oil squirting during pre oiling
Flysfloatsor
Banned
Im a little stumpted here.
Any engine guys out there.
Built a 383 and was pre oiling this weekend and Oil is gushing out of a hole right on top of the oil filter receptical.
It doesent have NPT threads, or else Id just plug it.
Was one of pound in plugs suposed to go there? I didnt think any were missed?
Ill attach a pic of the problem hole but its on my engine. And a pic of my engine for good measure.
Josh P
Re: SBC Oil squirting during pre oiling
well that port is for an oil pressure sending unit..it should be NPT....1/8'' i believe.... can you get a pic of what your talking about on your engine..
Flysfloatsor
Banned
I also have an oil pressure port at the top of the engine on the rear galley wall.
The hole by the oil filter location is not threaded on my block.
Ayuh,... In the picture, it appears there's the remnents of an old fitting in it...
Flysfloatsor
Banned
Correction: That orange engine is just a pic of the hole Im refrencing. Not my Engine. Mine is in the other pic with the polished manifold.
Ill get a picture tonight.
Flysfloatsor
Banned
I tapped the hole 1/8 NPT and put an oil pressure gauge in the upper oil pressure port. Then ran it on a powerful drill and got a solid and consistant 75psi with cold oil.
LAC_STS
Master Chief Petty Officer
On my engine there is something threaded in there with some wire connections on there. It maybe called a sender I dunno but the wires that connect to it male the fuel pump cut off if the oil psi is low or nothing.
I think that's where the sender goes that controls the fuel pump. I have a sender for the oil pressure gauge on the back of the intake Mani too.
