I was thinking that either the phillips head screw (pivot pin) was misaligned, or the shift rod coupler was undone. You might take off the little access plate on the side and check to see if the coupler's come undone.
tx1961whaler it was the shift rod coupler problem solved thankyou so much, I thought this was going to be a major tear down, i over looked the simple checks. Thanks again
