Trying to order three gauges for my DT 55 (1997) Suzuki. First, I'd like to get a Teleflex tachometer from I Boats, but do I need a tach specific to this engine or will any tach work? Original equipment was a multi-guage that just showed an over rev limit, while I would like to know the actual rpms. Will the sender on the motor work with a new tach or will I need to order a motor specific tach and sender?
On the voltmeter, I have a choice between a battery condition indicator or a volt meter. I assume that either will work and will only require a simple hookup to the positive and ground in the console. Any real difference between the two?
I'd like to add a water temp gauge. Again, if I just order any Teleflex, will it work with the sending unit on the Suzi or will I need a matching sender?
Tried to call I Boats help line, but no one there on a Sunday. I can try again Monday or see if someone here can steer me in the right direction.
Thanks for any assistance.
