Re: Center Console Control Panel
Welcome to iBoats
I assume this isa new-to-you boat.
some of them may be spares and not hooked to anything; look underneath and see.
If there is a switch that has 3 positions, it's for your running lights.
The ones with a red light are often hooked to a pump (live well, bilge) so you know when it's on. Even when my bilge pump is on auto, the red light comes on if the float switch is activated. Locate the bilge pump and the livewell/washdown pump(s) and see if they make noise when you flip a switch.
There is no hard and fast rule about how they are hooked up.
My new-->used boat had the switches labeled but the sun faded them; see if you see anything still there.
Even if you found a on owner's manual, the diagram might not match your actual set-up.
