Re: Minn Kota Troubleshooting
Did you move the speed control up and then step on the "go" pedal. If the speed control is set to "0" that's the equivalent of OFF. If the "go" pedal doesn't seem to do anything, set the MOM-CONT switch to CONT (continuous). In the continuous mode the motor will run constantly at whatever speed you have selected without stepping on the "go" pedal. If this doesn't work, you have a bad connection in the plug from the pedal. Disconnect and reconnect it several times to ensure the contacts are clean. I did not see "V2" in your description so I assume this is a used PD with the flat connector rather than the smaller round connector found on the V2. If you bought a used motor there is a good chance you also bought a bad foot pedal.
