ok-
Hi to all in the starcraft forum-
Just picked up a 1971 starcraft islander 21'er. Darn thing was free- so I took it home. It has a a few issues- 1st- thing is sorta ugly 2nd- it was a prior I/O but now it has a gill bracket and a 1993 rude 150 on it. 3rd- p/o removed the floor and installed aluminum diamond plate instead of wood/carpet. 4th- they started removing the cabin area for ???? reason. 5th- I found a .10 hole in the front at the base of the keel. It is obviouse they beached this boat a few times so it has worn a small hole thru the metal.
I got it just because the engine runs like a top. Had plans of stripping it down, keeping the engine and twin 30gal tanks- then scrapping the rest. But after looking at the boat for a while, I am leaning on patching the hull, removing the cabin, removing the aluminum flooring and redoing the boat like a old style utillity boat. I mean the sides are super tall, and I think the boat, after she is done with the 150 o/b should fly. Just throwing this idea out there- any feed back?? I havew seen a couple of guys cut them up and make cc's out of them. I already have a cc, so I thought about the whole utillity idea. It would be diffrent, and I think if planed out, would look kinda kool.
