flintcreek
- Apr 19, 2009
- 90
I have a 35 hp 1981 Johnson and it is jumping out of gear at WOT every once and a while. Tore into the lower unit this morning and the clutch dog and gears look good, very little wear. What should I check now? It thought the gear shift linkage was adjusted up good. Any ideals, what have you seen? Headed back out to the shop to check and see if it might be play in the bell crank.
Thanks,
Flintcreek
Thanks,
Flintcreek
