Re: Merc V6 dual float carb.Need help with Part #.
WH 35
Merc/Mariner 135
Main jets .050"
Idle Jets .060"
Vent Jets .094"
Should be late enough to have the hard plastic floats in em. That's good.
1395-6452 GASKET AND PACKING SET $7.30
1395-7826 REPAIR PARTS KIT (WH-32)(WH-35)(WH-38) $104.12
27-904301 GASKET, CARBURETOR $1.40
I'd get the packing kits and base gaskets. Usually there's nothing wrong with them except failed gaskets, dirt in the needles, etc. If you need a needle and seat, you can buy it separately, and if you need a float, yer in for a search. Usually wind up buying used carbs on eBay to get them. Goods news is the hard plastic floats seldom fail. Pay real close attention to all the small gaskets, like under the input seat, and the center bowl gasket. Bowl screws need to be torqued real even.
hope it helps
john
