http://www.xantrex.com/power-products/inverter-chargers/freedom-hf.aspx
I need some help getting my brain moving in the right direction. I just ordered a inverter/charger.. (the same one as the link above) Im wanting to wire it directly into my AC system. I also will be adding a 2 bank charger. I have 5 batteries. Im using 3 for the inverter/ house batteries. and 2 for starting batteries. The inverter is a also a charger. The set up I have now is seperated and controled by a 3 position switch. (1 only) (2 only) and (both). Can anyone tell me if I need to do something diffrent as far as seperating my battery banks or will this work just fine.. Also since the (a) charger and (b) charger/converter will be drawing from the same AC-shore power source is there some special way to hook these up.. I dont want to be running my (a) charger with the inverter when its NOT connected to shore power.
If you have any experiance with inverter direct wiring.. Honestly any info would help... Thanks..
Ron
Ron
