Mercruiser
sdolden
I recently purchased a 96 crownline with 4.3 v6, I ran it a couple days after I bought it and it ran fine. About a week later carried my family out and ran it for about a hour, stopped for about an hour and then it cranked up and we ran down river for another hour. The boat started acting sluggish, it backfired and then died. It would not crank after that. Replaced fuel filter, checked firing and made sure fuel was getting to the carb. Any suggestions would be appreciated.
Don S
Re: Mercruiser
Did you check what was in your old fuel filter? If it was full of water, which it sounds like, then the carb is also full of water.
Put a couple of tablespoon fulls of gas into the carb and see if it fires.
Re: Mercruiser
Ayuh,... That's a Good place to start the diagnosis...
fossill
Re: Mercruiser
Yup, Just keep a fire extinguisher handy when you do that....just in case Murphy's near by.
