94' 40hp Mariner oil level alarm
marquezrm
Bad design found the magnetic float in the oil tank must replace tank, the stick switch at the bottom is replaceable when I retract the stick switch 1/8 of an inch the variable alarm stops with key on or running. I did drain the tank and cleaned the float with a spray cleaner moves freely refilled tank. Before I purchase a $60 tank has anyone seen this before. The troubleshooting manual recommends changing the tank first and if that doesn't work the controller $184.
Thanks
marquezrm
Re: 94' 40hp Mariner oil level alarm
No luck finding a procedure to replace what is probably a $2 Magnetic float so, r&red tank prob fixed.
Thanks
