no spark on 1 cyl, swapped coil to another cylinder and the problem followed, so assumed bad coil. Replcd that coil and still have no fire on that cylinder. I did swap coil again on the powerpack and got fire to that cylinder. SO... does this mean i have a bad powerpack now or could we have something else going on? If so by what means can i test and prove this.. I dont want to just start buying parts...
also, if we have to crank motor with a gas filled rag over carbs, does this indicate a lack of fuel issue. It will crank this way and once it does will idle fine (obviously with a miss and we are not running it long at all). I have taken carbs off and apart and soaked 3 days in carb cleaner, then thourouly cleaned each carb before reassembly. Not sure if there is a simple way test anything on fuel system i.e. fuel pump, diagphram etc...
any and all help will be greatly appreciated, im just about to get discouraged. Bought the boat and havent put it in water yet.... I do have original service manual for this motor too..
thanks
thanks
