Okay, so I have a 2.3L Ford/OMC. New plugs, new coil, new timing belt, new fuel/water separator, carb float bowl disassembled and cleaned.<br /><br />It will start at full throttle after pumping alot and will run for about 2 - 3 seconds then quit. I can get this to happen twice before I have to recharge the battery.<br /><br />The fuel pump is pumping (halfway across the boat when I disassembled the fuel line and cranked the engine).<br /><br />I have worked on car engines most of my life, but this definately has me stumped.<br /><br />We just got the boat second hand. The previous owner says that it was running fine previous to being winterized; however, the engine was timed 180-degrees the wrong way. This makes me a bit skeptical so I am basically starting from scratch. I re-timed the engine (best I could without it running).<br /><br />In short: HELLLLLPPPPP!!!
