Hello everyone,
I have been working with an overheating issue on my 1997 200 EFI Mariner Magnum. (previously posted as a 1996...duh!). My symptoms are as follows: When I launch the boat, sometimes I get the steady alarm fairly quickly after launch, but other times only after a short run and after coming off of plane. Other times, I get it when at idle. The other day I removed the thermostats and checked them and they both opened up at 143 degrees. My tell tail stream is not super strong, but it never has been really. I have ordered an impeller kit and two new stats just to be safe. My question is does this motor have a poppet valve? I have a Seloc manual, and it doesn't really show it for my model, but it isn't the greatest manual either. It is my understanding that the valve opens up and lets excess water out through the prop exhaust when the pressure in the water system reaches a certain level. Just wondering if anyone knows if this model has a poppet valve and where it might be located. Model # OG486920 Thanks!
