1979checkmate
- Jan 15, 2011
- 261
okay, i just got done replacing the ignition switch in my 1979 MerControl for same year 115 inline 6. I have a problem though, a leftover wire in the harness that is not used anymore. The way i have it wired is as follows...
Harness.....switch........use
red............red...........battery power
black.........black.........ground
gray......yellow/black...choke
yellow...yellow/red......solenoid
orange..black/yellow....short/kill
N/A........purple...........ignition circuit (acc.)
white?....??????..........???????
THe white wire from the engine harness is the wire that i cannot figure what it does. THe motor turns over fine, and there are no extra wires on the switch (6 wire switch). Does anyone know what is up?
