leadpencil2
- Jul 9, 2009
- 34
Actually two questions, I am trying to troubleshoot a tachometer problem. First let me say the engine is running perfectly. The Tach Airguide (with sending unit) is pegging out at anything after about 800 rpm. I am trying to narrow my issue down to the tach or ignition. Now for the 2 questions: Does anyone have the parts diagram (exploded view) for a magneto ignition? My 1966 parts diagram only includes the "Distributor group" or automotive type ignition. The 2nd question is more of theory verification. If I understand how the tach works correctly it basically is reading the number of pulses coming from the ignition (how fast the points are opening the closing). Is it possible for the engine to run correctly but for the engine to not pulse or for the signal to be "grounded out" by something? I'm thinking the signal is being interrupted somehow. Thus the reason for the Magneto diagram. I sent the tach out for a function check and it came back working/operational. Really at a loss, any help would be fantastic.
