Whinning from lower unit
tdesilet
I have this Whinning sound coming from my lower unit in the water, I can not hear it out of the water running in my driveway. Does any one know what this may be? I also can hear a knocking sound coming from the lower unit when I am running it in the driveway it is not all the time just ever now and then. PLEASE HELP QUICK!!!!!<br /><br />Thank You :D
nodumdrivers
Re: Whinning from lower unit
have you checked the fluid? dirty? contaminated with water? could be a bearing problem or something actually on the engine like a bearing or belt. just my thoughts. goodluck.
tdesilet
I drained the fluid and replaced with new fluid, no evidence of metal,dirt, or water. With the boat in the water I opened the engine cover and the sound was not coming from there, but when I went to the back of the boat the whinning (high pitched) got louder.<br /><br />Thank You for the reply
So WHAT Was It..???????
tdesilet
The bearings in the upper gear housing got hot and expanded and pushed out the races of the bearings an started to cause it to whinn. Replaced the bearings and now it runs and sounds like a champ. Thank You
