I have a 50 HP Force model number 507F4A. It is a 1984 model and when pushed to full throttle the cam lobe that pushes against the carb butterfly will not max out. It only rolls about 1/4 of the way up but can almost hit full throttle if done by hand, but still does not go all the way to the notch at the top of cam. Also when moving the throttle arm, it will go halfway before any of the linkage starts moving the butterfly on the carb. I am trying to figure out where I am losing leverage to hit max throttle. Any help or tips would be greatly appreciated.
