Hi, my engine will not go in reverse when shifted from the controls. I can undo the linkage and it will shift fine, from F N R, when manually shifting the shift rod. But when I hook the linkage up, even though the shift rod is hitting the same point, for some reason it will not even come close to going into reverse. Any ideas? Thanks
