shadowdwpp
- Jul 10, 2003
- 57
At the end of the season last year when at Idle and also when revving in neutral My temp gauge showed 220-240 until underway after noticing this I brought it in and asked the marina mechanic to take a look he said he would but never did I brought it back this spring to the dealer I bought the boat from. I had them check and replace the thermostat and water pump and told them to flush the cooling system. It is still running hot at idle are there any suggestions I could have them look at to lower the amount of time they spend diagnosing the problem. I told them to check the temp gauge on Monday I'm going to tell them to make sure the sending unit works ok. It seems to be taking a long time they've had the boat since 5/13 I'm hoping to at least get it on the water before July 4th I've already lost the whole spring season.
