Re: no reverse - mercruiser Alpha 1- 1984
could have also forgot to drain and refil the fluid. If it wasnt kept in a climate controlled environment, anything coulda happened inside.<br /><br /><br />But in any event, hold the rod into the forward postion and spin the prop counterclockwise and push the drive in. You mighta fouled up the linkage. <br /><br /><br />-- Joe
