natecollins1
- Jun 30, 2006
- 37
Hi,
I am working a 1991 Force 150 w/ thunderbolt ignition. This particular motor has a converter box that take 12V DC voltage supplied at the starter solenoid and converts it to AC voltage for the switchbox. Can anyone tell me how this unit works internally? I believe that it is killing the battery. The battery loses its charge overnight if everything is hooked up. When I connect the red lead from the converter box to the starter solenoid, it sparks. This tells me that it is drawing power from the battery. I would think this used should switch on an off (maybe controlled by the switchbox) but am not sure. Any help would be appreciated.
Thanks,
nate
Thanks,
nate
