virginiajetboater
- Mar 22, 2011
- 5
I have a 1995 Mercury 90/65 jet outboard. When I go past 3/4 throttle RPMs will suddenly drop by about 1/3 (I have no tachometer). If I let off the throttle just a little, RPMs suddenly come back up to normal. I thought this was a fuel problem, so I replaced fuel line, primer bulb, fuel filter, and rebuilt fuel pump. Poured a can of Seafoam in gas tank and ran boat-seemed like I could go a little past 3/4 throttle without RPMs dropping but still could not go to full throttle. Tried some more Seafoam with a tank of high octane gasoline-now worse than ever-cannot go past about half throttle without RPMs dropping. Started thinking maybe ignition problem. Pulled plugs (which were less than 6 months old) they all looked fine but replaced them anyway. Boat ran perfect for about 15 minutes-full throttle the whole time. Turned around and headed back to ramp and there it went-sudden drop in RPMs. I lift up on throttle just a little and RPMs come back. As soon as I go to full throttle, RPMs drop again.
