I wondered if anyone can guide me through checking the timing on my 135 v6 mercury 1989,its the model with carbs, my manual still hasnt arrived and I would feel more comfortable if I check the igition timing proir to using it at the weekend, can anyone run me through the setting it should be at,I have noticed the markings on the flywheel,but am unsure of the procudure,not sure which plug is classed as No1(if thats the one to connect strobe to)not sure the revs/degrees to check,it does have the plastic cowling over the flywheel with ajustable pointers on too,
I thank you in advance
With best regards
Grant
With best regards
Grant
