dieseltruck
- Dec 11, 2010
- 5
some one out here has to know or heard of my issue. again its a 1999 225 yamaha ox66 vmax fuel injected.i have replaced all 3 Lp pumps pulled and cleaned the vst tank and mesh filter.i have pulled and cleaned the o2 sensor.ran motor on seperate fuel tank with can of seafoam when i could get it to run for more than 30 seconds.i have found now with the key on the pump is on for 3-5 seconds the motor will start runs for about 15-20 seconds then acts like it runs out of fuel. what we found is the ground loop is not closing to keep the fuel pump running.the ecu is holding out the ground.can anyone help lead me in the right direction to look for the issue. thanks again for any responce to my issue.
