Re: 1999 25 mercury 2-stroke alarm
Never seen a alarm on a 25hp, 2-stroke but I do know there is a port for a temp sensor on the top of the water jacket on the head. Look at it and see if there if there are wires going to little sensor on the head water jacket. If so then you have a overheat alarm. The only thing that would trigger a alarm is either the thermostat not working correctly or the water pump not pumping enough water. I think the thermostat opens at 120 degrees which means at idle you should'nt have a steady stream of water out the pee hole....and the motor should be running around 120 degrees all the time. If you do replace the thermostat...be very careful removing the bolts in the housing, they are very thin and break very easily if they are corroded. The waterpump is very easy to change, and if you havnt relaced it in few years, then it's time for a service.
