This motor starts easy enough but overheats in a matter of minutes.
I dropped the leg and flushed the water channels backwards with good flow coming out the water input tube.
I replaced the impeller whilst the leg was off (nothing wrong with the original either)
I get a very strong stream from the telltale so i assume the water cooling system is fine.
Ive noticed that the right hand heads are too hot to touch but the left side are not too bad.
Ive researched a bit but no one answer stands out.
At a loss and any suggestions before taking to a boat mechanic would be appreciated
