I have a Zodiac Pro II 470 RIB. It used to have a dual nav light on the front of the console. I got a new console and have to come up with new lights. I was thinking of putting a post light in the bow. This boat does not have a bow compartment built into the hull, so I'll have to come up with a mounting bracket. My real problem is getting power up to the front of the boat.
Zodiac tells me that there is internal structure to the hull and gave me a diagram from a different boat and said mine would be "similar". Since there are no access panels to the hull I would have to cut holes. I could make holes in the deck easy enough, but drilling any horizontal holes to get wire to front would be tough.
I was thinking that I could run the wires up the side under the tube between the tube and the outer part of the hull. I would deflate the tubes, run the wires and cover them with waterproof tape, and then re-inflate the tubes. For LED lights I'd only be using 16 gauge wire.
Does anyone think that there would be any long term consequences to the tubes if I did the wiring this way?
Thanks.
Thanks.
