Hello Guys
I have an old 1970s ski boat (15 foot 350 chev) that I would like to put a high pole in. I am a pretty competent welder etc so I will make one up myself however I am unsure where to mount it. I have two hull beams running along the length of the boat (of which the engine brackets are bolted to) the obvious place is to mount my bracket just over the front keel and in front of the engine onto the wooden beams. However as these beams are surrounded by fibre glass I can not get to the other side so would not be able to run a bolt through them. I am wondering if some heavy duty wood screws would do the job or would this put too much strain on the wood.
I have attached a rough sketch of what I want to do ? the pole would be 2inch by 6 ? 7 foot.
Thanks
Tim
Thanks
Tim
