Re: 1967 Johnson 9.5 drops speed in drive
Have you had any recent work done on your lower unit?? Does it kick in and out of gear suddenly when you are planing out?? If none of these symptoms are happening then you may have some type of ignition issue.
Are the coils original? Coils, when starting to go bad or have become cracked will intermittently fail at running temps. The insulation cracks and become compromised. It would be a good thing to inspect your coils, points, condensers, and points. It may be intermittently running on one cylinder. Please check your wires to make sure that are not compromised, cracked or old. You could have a grounding effect. Some members have shown video of there motors in the the dark arcing on the motor.
Here is a link by JBJennings that does any excellent job of describing the tools needed and how to go about doing the inspection and possible replacement of ignition parts.
http://forums.iboats.com/showthread.php?t=294072
You can only adjust 1 point at a time then you must rotate shaft to do the other ,you can't adjust them both at once as one is in the closed position and the other is in the open mode. The rubbing block must be on the high lobe of the points cam (points open) this would be the gap setting position, turn the crank by hand and observe the rubbing block while also watching the points open, the rubbing block will remain on the high spot for a few degrees of turning the flywheel before it drops back off. (Place the flywheel nut on the crank shaft and use a wrench or ratchet set to turn it.) Please make sure the spark plugs are out so you don't accident start the motor.
Don't forget to make sure there is an oil wick in place. Don't want to prematurely wear down the point shoes.
Here is a link to a electronic parts diagram to your motor. (ignition parts can easily bought here at iboats
http://www.boats.net/parts/search/BRP/JOHNSON/1968/MQ-14D 1968/parts.html
Hopefully one of the 9.5hp Evinrude/Johnson experts will bite and give you a hand.
Oh, by the way
tx1961whalerhad an excellent suggestion of checking your motor to make sure it is cooling properly. In addition of check to see if sufficient water is coming out of the exhaust relief hole, also check to see if your motor is not becoming blazing hot. Digital laser thermometer are decently priced. Your running temps should not be higher than 165 degree F.
Please keep us posted!
