pvancorenland
- Aug 26, 2010
- 40
When I replaced my u-joint bellows, I found a blob of _dark_ grease behind the gimbal bearing as expected from adding grease to the bearing grease zerk, but I also found an oily substance covering the bottom of the bellows. It looks yellowish and smelled like _fresh_ motor oil.
How could it have gotten there? There was no apparent leakage from the gimbal side, and the seal on the outdrive looked clean as well. The bellows were intact.
I had changed my outdrive oil right at winterization and ran the outdrive for maybe a minute afterwards.
Outdrive: Volvo Penta DP-SM, gimbal housing: SX-M, Engine: 2001 VP 5.7 GSI
