18 horse evinrude lower unit
redmen18
can't figure out how to completely drop lower unit to replace water impeller it's a 1959 evinrude 18 horsepower fast twin unbolted lower unit but it only comes down about an inch dont know whats holding it on new to this any help would be greatly appreciated
tx1961whaler
Re: 18 horse evinrude lower unit
The shift linkage needs to be disconnected. There's an oval plate on the side of the exhaust housing held on by two screws. Remove the screws and the plate and you should see the shift coupler under there. Remove the bottom screw in the coupler and the lower end (with the shift rod) should come out.
HighTrim
Welcome to iboats.
You have to disconnect the shift rod to let the lower unit come off fully. There will be an access door on the side of the leg, about 1x2, take that off, then you will see the shift rod, connected with a coupler. Remove the bottom screw in the coupler, and the lower unit will drop. Put a couple of the bolts back in to take up the slack, disconnect the shift rod, then drop the gearcase.
If you need help with the water pump install let us know.
samo_ott
Hmmm. Can I say the same thing also? Disconnect the shifter! :)
samo_ott
Dang. Is that the protocol? You Vice Admirals. You're all the same! Us Rear Admirals are still learning the ropes!
