So, here is my dilemma...
I have a 'new to me' 1984 Bayliner 1900 with the Chrysler/Force 125 O/B but at full throttle I'm getting 42mph (GPS) and 4200rpm.
I am going to replace the fuel pump but everything else looks great - new plugs, carbs seem to be in tune, need to check timing advance but I don't think it's adjustable (is it?)
The boat came with 3 props so I need to get the numbers off them but at what point do you start changing props around and how do you know that the engine is producing it's intended hp - I don't want to change prop to mask a poorly tuned engine.
So I guess what I am asking is what speed should I be getting from a 19' Bayliner with a 125 OB?
If 42mph is fair then I can guess that then engine is producing the goods - and then I can tweak the prop - if it's a bit low then maybe I should have the motor tuned first.
I'm trying to decide what the next step should be. Not having a lot of spare cash for boating, this is a DIY job.
