I have a 1986 Mercury 35 mounted on a 13' Glasstream fiberglass bass boat. The last time I used the boat it was running great around 5000 RPMs and suddenly slowed. The gas was low so I thought it was running out of fuel so I went to shore loaded the boat and went home. When I put the boat back in the water it still wont go but around 1500 RPMs at WOT. It cranks up great, idles good, has 150psi commpresson on each cylinder, new primer bulb/hose. At WOT the carb butterfly is wide open. It runs smooth, no skipping or smoking, just wont get over 1500 RPMs. Any suggestions? Thanks!!
