oldboatguy
- Oct 24, 2007
- 44
70 hp 3 cylinder evenrude worked when I took it out for the first time
this year went up fine would not come down. let it down with the pressure
relief screw, now will no go up or down
I refilled fluid and tried to bleed out the air any thoughts the two trim cylinders will move if no weight is on them but donot trim motor the
power tilt motor runs and sounds normal . you can lift th motor manually
bu if you turn it loose if just goes down...... help
