Re: 1966 Johnson FD 20C
I just tuned up my FD-20C with new points, condensers,coils and cleaned carb. Now it runs really good. I read alot of the posts here and found lots of good advise on this motor. One thing that stands out is the spark gap test, if the spark won't jump 3/8'' that cylinder will not fire. I had spark on both plugs but it wasn't untill I bought a spark gap tester then I found spark was weak on one cylinder. One more thing I bought four new coils and one failed after two pulls on recoil, and wouldn't you know it I installed it on the same cylinder that was weak in the first place. After fixing spark issues I ran in a tank to set carb but I thought it should run better and remember reading about the link sink here, and noticed the timing cam had a grove wore into it,so I had to adjust very little. Now it runs very good. good luck.
