Re: Troling Motor and fishing
Dingbat is right on level of bait. As for trolling with your bayliner, If you can go about 1.5 mph then go for it. A trolling plate works good on some outboards, and I've known some people to use them on inboards also. It blocks the water coming off the prop, but be careful not to give the motor too much power, or you can break the cavitation plate. A fishfinder can tell you the depth the fish are, and you want to be 2 to 5 feet over them. Some fishfinders have speedometers on them, but they are not that accurate, or at least the ones I have used. A cheap hand held GPS can give you about the most accurate speed. A downrigger can get you down deeper for the deeper fish, but how much do you want to spend? You can also still fish from a boat, just like on shore, like for bass, or fly fish. The boat gives you a lot more options, I like Jigging for Mackinaw trout, or ling cod when I can, and that is still fishing about 200 ft deep.
