nautolex vinyl floor glue what glue should i use
watrbug
im presently rebuilding a 19 ft sea nymph and i,m installing nautolex vinyl i used the original nautolex glue and it didnt seem to work very well on my test piece the hatch covers and small lids i used contact cement and it seemed to work very well but that would be very hard with a large sheet of vinyl, i need and answer m thank ted
MaddysDaddy
Re: nautolex vinyl floor glue what glue should i use
did you allow the water to leave the glue and tack up before you installed vinyl?? that is very important.
watrbug
i,ll try it today as soon as i get started thanks did you ever use the water base nautolex glue?
ezmobee
I did mine with their glue and found it to work very well.
