1972 Johnson 9.5 Not draining water
BoggyBoy1995
My 1972 Johnson 9.5 runs but does not drain water. I checked the water pump and it was perfect condition. Any Ideas?
Barnacle_Bill
Re: 1972 Johnson 9.5 Not draining water
The tube could be clogged up. Run a piece of weed wacker line up it while the motor is running to clear it.
BoggyBoy1995
Im not sure where to run the weedwacker cord while its running.
e10
9.5s don't have a water indicator like newer motors. I think they have an exhaust outlet at the back that water will "mist" out.Next time you have it running hold your hand on the top of the cyl head and feel if it is warm.
BoggyBoy1995
I shot compressed air through the copper tubing to see if I could get anything out of there then i shot water through the copper tube and it didnt come out of the pee hole
