Yankee817299
- Mar 17, 2011
- 11
Hello all, I am a newbie here and have a few questions for all you guru's. Just acquired a 95 Four Winns Horizon 200 with a OMC 5.0L engine powered by Penta. The boat came to my wife through her long drawn out divorce. She was told by her ex in his attempt to persuade her to leave him the boat that the engine was blown and the hull was damaged. When we got the boat to our house, there was no hull damage, the engine looks to be all there, no oil or fluid leaking in the engine compartment or in the bilge area under the engine. The engine oil is at the proper level, and looks like new oil. On the out drive, the fin right behind the prop is broken off at the bottom. Probably 3" x 5" piece.
What we would like to know, what can I look at to determine the condition of the engine. I don't want to crank it if there is any internal damage. I was thinking first, to pull the plugs and see if I can rotate the crank by hand??
Also, on the out drive, can a piece of alluminum be welded back onto this and polished?
Any advice sure would be appreciated.
Just a note, I do light mechanical work on my car and have 2 Kawi jet ski's that I also wrench on (2cycle's). Not real sure on what's inside the engine compartment on the boat, but readilly able to learn.
