Re: asking to much from my boat?
You are asking a lot from your combo to pull out a slalom skier with more than a spotter in the boat.
Going up in pitch will only make matters worse. It will reduce the acceleration and pull needed to pop the skier up.
You are at the middle of the full throttle range for that engine so an increase in pitch will drop RPM by another 400 for a 17 pitch and 800 for a 19 pitch. Both will reduce performance. Unless it is an aftermarket prop, the "16" degree you have on now is really 15 pitch.
If you know someone with one OR if you can test a prop, a 13 X 15 stainless will increase performance a bit..
Also, you need to trim in the engine when first accelerating the skier, then as he pops out, trim out for best speed. Have passengers move as far forward as possible to get the bow down and the boat on plane as fast as possible.
As mentioned above, 25 MPH is just a bit slower that should be expected. Check the hull for excess weight and check the engine to see if it is delivering performance--at a minimum check compression to be certain it is not too low. Go to the Force forum and at the top sticky, read FAQ and see if your engine is synchronized correctly--carbs opening fully, timing fully advanced, etc.
If money is not a factor, go to the auctions and find a 2 to 1 ratio lower unit from a 90 HP engine. Your current ratio is 1.76 to 1 and inhibits the engine's performance with any prop.
You can use any lower unit from 1979 Chrysler through 1990 Force. Just be sure it comes off an engine the same length as yours--that is 20 or 25 inch leg.
