Re: Will a 150 hp Force lower unit fit a 125hp Force motor?
Split drive shaft has the same splines up top where it enters the crankshaft until the Merc designed midleg and lower unit was used. So, yes, you can swap them. AND if you can find a reasonably priced upper shaft in your size, the same lower unit and stub shaft will fit on 20 and 25 inch engines.
